13 years ago[DE1] Making the VGA works with the IP VGA Controller
Hi all, I have a question about the DE1 Board. These day i am working on a project with SOPC and Nios II. My objective is to control DE1 feature directly in C with the Eclispe tools. Actuall...
13 years agoHi all!
I'm new in DE1 KIT. I'm building a SoC that displaying data from SDRAM into he screen through VGA. My SoC contents: - Nios II - On-Chip Memory -JTAG-UART - System ID - SDRAM - VGA I want to display data from SDRAM to VGA by using DMA for reading data from SDRAM to VGA. My C program write data to SDRAM by NIOS. Then I use DMA to read data from SDRAM to VGA. When the interrupt occur, DMA will read 640 value (1 line) from SDRAM to VGA. My VGA core has a FIFO to buffer data. When fifo is empty, the VGA core will make a interrupt signal to control the transferring of DMA. My system has some problems such as: - First: When I use NIOS II to verify the read, write of SDRAM, it operates unstablely. I use "for" loop to write and read data to SDRAM but it just correct in the first 154 values - Second: When the interrupt occur, DMA only operates within two loop, in third loop, DMA reports the error : "Can post request..." Anybody can help me. please! Thanks so much!
