15 years ago
DE1 board : SD-RAM expansion possible ?
for my project , simulating a vintage disk drive ( DEC RL02 ), I have not enough memory ( 8 Mbyte SD-RAM ) available on the DE1 board. The SD card can't be used in my case, because a SD card can only be written a limmited number of times. It would be very helpful if I can expand (doubling or tripling) the 8 Mbyte SD RAM.
Does somebody has an idea or note ?
( Replacing via soldering the SD-RAM chips is not possible for me )
Is there a memory extension available via expansion header connector ?
Or, a hard-Disk adapter for the SD-Card connector.
At least, has somebody a recommendation for another development board ?
Thanks an regards, Reinhard
    I don't see why you couldn't put another RAM onto one of the 40-pin connectors, but it would have to be either SRAM or (non-DDR) SDRAM because you're stuck with 3.3v i/o. As far as I know, only SRAM & SDRAM have 3.3v i/io - all the good stuff (DDR, DDR2, DDR3) is < 3.3v.
    This was what was so frustrating about the BEMicro SDK - it has the nice 64MB of DDR SDRAM, but uses Mobile DDR SDRAM with little-to-no documentation, so you have to fork out for the ip before you can use it for more than 30 days... Great cheap board, cr@ppy licensing.
    In terms of other boards, the next-step-up (DE2-115, $299 academic, $595 for hobbyists like me) has 128MB of SDRAM and 2MB of SRAM. If it had a PCIe connector, I'd have bought one by now :)
    Simon
    Many thanks for the upgrade infos !
    The DE0-Nano will be my new favourit. This board is very reasonably priced
    and it schould not be a problem to add a SD-Card connector ( in my case, to be able to load the entire vintage-disk contens from SD card to SD Memory ) ?
    Regards, Reinhard
