18 years agoDE1 AS Mode Problem
Hello, I have the DE1 kit and I use Quartus 7.1 under win xp2. I can jtag program without a problem but I cannot get the programmer to show me AS mode. (I can do a SFL using jtag OK) When ...
18 years agoHello Frank,
Thanks for replying. I don't know why that option doesn't appear. I downloaded the stand-alone programmer and I get exactly the same problem. Do you know if that option appears only when it recognises the config chip ? When I want to change mode I just move the switch to PROG, then do an autodetect. Is that correct ? At the moment I'm using .jic files and SFL to config the chip - that works without any problem. It doesn't look to me like a hardware problem - I wonder if there's a non-default setting which needs to be changed somewhere. Best jt2
