18 years agoDE1 AS Mode Problem
Hello, I have the DE1 kit and I use Quartus 7.1 under win xp2. I can jtag program without a problem but I cannot get the programmer to show me AS mode. (I can do a SFL using jtag OK) When ...
18 years agoHello,
may be I missunderstood your question, but I believe, Quartus Programmer can always be switched to Active Serial mode, even with no programming hardware connected. There could be an issue that no AS configuration device is indentified, but this could only happen after selecting AS mode. Why can't you select AS mode in the drop-down field? Regards, Frank
