15 years agoDE0-Nano, Configuration via Passive Serial
Good day,
I've already bought a bit DE1 and fully satisfied with it. Now I wanted to order DE0-Nano for my project. It is configured using "Passive Serial" means PIC32. In the circuit diagram of DE0-Nano I think unfortunately no information where the "DATA0" lead "CONF_DONE", "DCLK", "nSTATUS" and "nCONFIG". Is it possible to configure DE0-Nano via PS? Dmitriy p.S. sorry for my english...2 Replies
Hi Dmitriy.
I don't one one, but since it has a EP3C16, it looks like it's probably setup as a Active Serial configuration. The Clock, Data0, nSTATUS and nCONFIG should be all available, either at the EP3C16 or through pull-ups, but the mode select pins, may be hard wired on the board. The only way to find out is to get a schematic, but I couldn't find one the Terasic site. Pete - Altera_Forum
I have the schematic. It is at DE0 Nano-CDROM. There is no configuration PROM and USB-Blaster in the schematic. I can not understand if "DE0 nano" can be configured via AS. The configuration pins are on page 8 (bottom right), more is not there. I need the information of where these pins are connected. Dmitriy
