16 years agoDE0 board, mysterious LED behavior
I've recently been testing out a daughtercard I made for the DE0 board which includes a motor driver and connector for a quadrature encoder. I was testing some code I wrote to decode the quadrature ...
16 years ago --- Quote Start --- the FPGA is controlling I/Os in unpredictable ways --- Quote End --- Surely it doesn't. Everything is in your design somehow. First you may want to check in the pinout file of your design what's connected to the LED pins. It may be the case, that unassigned output pins of your design have been connected to these pins. If nothing is connected according to pinout file, a severe hardware problem must be expected however.
