DDR4 test failluer with BTS
Hi Ganesh,
I can suggest to test the DDR4 interface with an EMIF example design.
You can refer to the Arria 10 EMIF User Guide for reference.
I have an EMIF example design that targeting Arria 10 SOC Development Board.
You test the design on the board and compare the result the you're acquired.
I will attach the design later.
Please be informed that I will be OOO starting tomorrow until 16/4/2024.
Expecting some delay to provide reply in this forum.
Adzim
I'm attaching the design here.
This design was generated in Quartus Standard version 22.1.2.
You can follow the steps from the User Guide in section 1.8 and 1.9 to run the design.
There is a signal tap file that is ready to capture the signals of the DDR4 interface.
You can open Signal Tap Logic Analyzer from the Quartus's Tools tab and click on Run Analysis.
You should get similar result as picture below.
Please share your result of your test for observation.
Adzim
- Ganesh_sf2 years ago
Thanks AdzimZM. We tested the provided DDR4 design. Traffic gen fail signal "1" was received. Please find attached the wave that was taken.
We upgraded the design and tested with Quartus Prime 22.4.
We also observe that the provided design not matches with FPGA-DDR4 configuration which is 2 GB DDR4 (256Mb x 72 x single rank) - ships with kit.
