Ganesh_sf
2 years agoDDR4 test failluer with BTS
Hello, The development board I'm using is the Arria 10 SOC (10AS066N3F40E2SG). We attempted to use BTS for DDR4, but we were unable to carry out a flawless test. For further clarification, please re...
AdzimZM_Altera
2 years agoHello,
I'm Adzim, application engineer will assist you in this thread.
I would need to verify some information to me get better understanding about this problem.
Please provide your respond to my questions below:
- What is the Quartus version that has been used/installed to test with BTS?
- How many board that are failing and passing the DDR4 test?
- Have you checked physically that the DDR4 HILO memory card is mounted perfectly?
Adzim
Ganesh_sf
2 years agoHello Adzim,
Thanks for the reply. Find inline response below-
- What is the Quartus version that has been used/installed to test with BTS?We are using Quartus pro 17.1 to test BTS as Quartus Version 15.1 is unavailable.
- How many board that are failing and passing the DDR4 test?We tested it with the single available board, and it failed.
- Have you checked physically that the DDR4 HILO memory card is mounted perfectly?This DDR4 daughter card was factory-installed when we bought the board. If you look at the previously attached screenshot, we can detect the RAM.
Note that the BTS is operating properly while the GPIO and LEDs are being tested.
Ganesh
