AMa
6 years agoDDR4 校准不过
Hi 我们客户用了8片DDR4,分为两组,每组64bit。 布线前,分配IO检查过,fitter能跑过。 现在问题是,上电后,local_cal_fail拉高,校准不过。 我检查过时钟,给的100M 参考,与IP内对应,电源1.2V与0.6V的参考都是ok的。 上电后,IP的emif_usr_clk能正常出来,说明参考时钟正常进去了,然后时钟出来了? 我也试过降频测试,从1200M降...
AMa
6 years agoHi, Aida
Thanks for your relpy, I had solved this issue. The reason is Alert_n connect to 1.2V.
- NurAida_A_Intel6 years ago
Glad to know everything is working fine at your side now. 😊
Feel free to post any question if you need help/support in future.
Thank you and have a nice day!
Aida
