MHada
7 years agoDDR3 - CYCLONE V SOC FAILING ON HARDWARE
We have designed a hardware in which we have developed three boards using CYCLONE V SOC using DDR3 - 8Gb [3 numbers on every board] . In this we have found that 2 hardwares are working perfectly fine...
NurAida_A_Intel
7 years agoHi MHada,
You can also go through this calibration checklist to see if anything might be applicable in the issue --> https://www.intel.com/content/www/us/en/programmable/support/support-resources/support-centers/devices/cfg-index/calibration-checklist.html
I would also suggest you to generate an example design with same device and all the memory setting and see if the calibration pass/fail. If it passed, then you know that issue is possibly related to board issue or any other build issue. If it failed, then highly it’s DDR3 interface issue.
NAli1
