16 years agoDDR2-SDRAM on Cyclone III DSP Kit (no NIOS)
Hi, I am using the dsp development kit, cyclone iii edition (http://www.altera.com/products/devkits/altera/kit-cyc3-dsp.html). I wanted to use the DDR2-SDRAM but unfortunately there is no ...
15 years agoStefan_,
Did you ever have resolution on this? I am having a similar problem with local_ready from the controller going low and staying low. I know that the controller does get past the calibration stage and starts doing reads and writes. Then at some point, the local ready goes low and the controller stops accepting anything new. If you figured anything out in your design and don't mind sharing, it could be very helpful.
