16 years agoDCFIFO and AD9433 problem
Hi to all, I am currently working on a project using the Alter EP1S25 Development Board. I am sampling a signal using the on-board AD9433 analog-to-digital converter. To check if the sampling i...
16 years agoUnfortunately, i don't understand what you are exactly doing. Can you please tell about the involved ADC and DAC sampling rates and how the FIFO source and sink handshake signals (wrreq, rdreq, full, empty) are connected?
By the way, it's impossible to replay the ADC signal at a different rate continously. If you see a higher DAC output frequency (I assume you actually measure the output signal) than the ADC input signal has, it means that a block of data is repeated multiple times. You should be aware of, if you look sharp on it.
