16 years agoDCFIFO and AD9433 problem
Hi to all, I am currently working on a project using the Alter EP1S25 Development Board. I am sampling a signal using the on-board AD9433 analog-to-digital converter. To check if the sampling i...
16 years agoSounds like ADC and DAC are running a different sampling rates (e.g. 50 aand 165 MHz) and are connected to the FIFO without rate conversion. You should think over, what you want to achieve.
