11 years agoData from FPGA to host
Hi, I have a DE0-nano board and I compute data (only 4 bits generated at about 10MHz) and I'd like to communicate it to the host cpu through the USB-blaster so programs could read it. I've read th...
11 years ago --- Quote Start --- Yes I will take the time to learn but I don't understand everything. --- Quote End --- Neither do I :) --- Quote Start --- Please tell me what a BFM is exactly. --- Quote End --- A BFM is a bus functional model. Its a simulation-only component that allows you to generate standardized bus transactions, eg., Avalon-MM master transactions in this case. --- Quote Start --- And tell me what I should do (generate VHDL simulation files, create a simulation environment, look with Signaltap at what the stimulus should be...) --- Quote End --- Sorry, only you can do that, its your project. Cheers, Dave
