11 years agoData from FPGA to host
Hi, I have a DE0-nano board and I compute data (only 4 bits generated at about 10MHz) and I'd like to communicate it to the host cpu through the USB-blaster so programs could read it. I've read th...
11 years ago --- Quote Start --- Everything is corrected and it runs as specified in the tutorial! --- Quote End --- Great. --- Quote Start --- The thing is I don't know what difference it will make for my project. --- Quote End --- You should create your data capture logic, and simulate it, eg., create an Avalon-MM slave and then simulate it using the BFM. --- Quote Start --- First there would be many files to write and then I use VHDL so I have to translate everything from verilog (a language I don't know well). And what to look at? --- Quote End --- I also use VHDL. The Altera BFM can be used with either language. I also use Modelsim-SE which supports both Verilog and VHDL at the same time. The point of this exercise was to get you to look at a simulation. You may think its "hard", but its a critical part of designing with FPGAs. If you cannot take the time to learn the tools, then you will not succeed with your design. Cheers, Dave
