11 years agoData from FPGA to host
Hi, I have a DE0-nano board and I compute data (only 4 bits generated at about 10MHz) and I'd like to communicate it to the host cpu through the USB-blaster so programs could read it. I've read th...
11 years agoI read your readme.txt.Here is what I've done:
- modelsim ASE 10.1.d - set TUTORIAL - cd $TUTORIAL/qsys/qsys_system/simulation/mentor - source msim_setup.tcl - dev_com - com -> some warnings - vlog -sv $TUTORIAL/hdl/qsys_system/test/qsys_system_bfm_master_tb.sv -L altera_common_sv_packages - set TOP_LEVEL_NAME qsys_system_bfm_master_tb - elab +nowarnTFMPC -> --- Quote Start --- elab +nowarnTFMPC # [exec] elab # vsim +nowarnTFMPC -L work -L work_lib -L altera_common_sv_packages -L rsp_xbar_mux -L rsp_xbar_demux -L cmd_xbar_mux -L cmd_xbar_demux -L limiter -L id_router -L addr_router -L led_pio_s1_translator_avalon_universal_slave_0_agent -L bfm_master_m0_translator_avalon_universal_master_0_agent -L led_pio_s1_translator -L bfm_master_m0_translator -L p2b_adapter -L b2p_adapter -L transacto -L p2b -L b2p -L fifo -L timing_adt -L jtag_phy_embedded_in_jtag_master -L rst_controller -L mm_interconnect_0 -L onchip_ram -L button_pio -L led_pio -L jtag_master -L bfm_master -L altera_ver -L lpm_ver -L sgate_ver -L altera_mf_ver -L altera_lnsim_ver -L cycloneive_ver -t ps qsys_system_bfm_master_tb # Loading sv_std.std # Loading altera_common_sv_packages.verbosity_pkg # Loading altera_common_sv_packages.avalon_mm_pkg # Loading work.qsys_system_bfm_master_tb # Loading work.qsys_system # Loading altera_common_sv_packages.avalon_utilities_pkg # Loading bfm_master.altera_avalon_mm_master_bfm # Loading jtag_master.qsys_system_jtag_master # Loading jtag_phy_embedded_in_jtag_master.altera_avalon_st_jtag_interface # Loading timing_adt.qsys_system_jtag_master_timing_adt # Loading limiter.altera_avalon_sc_fifo # Loading b2p.altera_avalon_st_bytes_to_packets # Loading p2b.altera_avalon_st_packets_to_bytes # Loading transacto.altera_avalon_packets_to_master # Loading b2p_adapter.qsys_system_jtag_master_b2p_adapter # Loading p2b_adapter.qsys_system_jtag_master_p2b_adapter # Loading rst_controller.altera_reset_controller # Loading led_pio.qsys_system_led_pio # Loading button_pio.qsys_system_button_pio # Loading onchip_ram.qsys_system_onchip_ram # ** Error: (vsim-42) Unsupported ModelSim library format for "C:/Users/rm231795/Documents/work/JTAG/cellule/quartus/jtag_to_avalon_mm_tutorial/qsys/qsys_system/simulation/mentor/libraries/altera_ver". (Format: 4) . . . # Error loading design --- Quote End --- I can't post everything because of length limitation. The first error is a library type and I don't know what to do.
