11 years agoData from FPGA to host
Hi, I have a DE0-nano board and I compute data (only 4 bits generated at about 10MHz) and I'd like to communicate it to the host cpu through the USB-blaster so programs could read it. I've read th...
11 years agoBut the signals are changing depending on ext_clk that is about 100 times slower than the original clock and these signals are resynchronized by a fifo between the Quartus design and the Qsys system. It's not enough to say they are static?
And a "no matter" question: what is (is there) the command I have to use in Quartus to list the content of the working directory? I tried 'ls' and 'dir' but it won't work.
