11 years agoData from FPGA to host
Hi, I have a DE0-nano board and I compute data (only 4 bits generated at about 10MHz) and I'd like to communicate it to the host cpu through the USB-blaster so programs could read it. I've read th...
11 years agoHere is my problem of the day:
I'm using SignalTap II with three signal. The first one is acting as the clock and the others are represented on this image: https://www.alteraforum.com/forum/attachment.php?attachmentid=10256 ext_s0 is acting as the trigger on either edge so I would think it's constant before 0 but it's not. Can you explain?
