11 years agoData from FPGA to host
Hi, I have a DE0-nano board and I compute data (only 4 bits generated at about 10MHz) and I'd like to communicate it to the host cpu through the USB-blaster so programs could read it. I've read th...
11 years ago --- Quote Start --- Its a debug tool. Read the documentation. Try and use it. Once you understand how to use it, you will be able to determine if its useful to you. --- Quote End --- I used it some time ago and I know basically what it can do. I don't know it very well and I can be wrong but I don't think it could be very useful for the matter. --- Quote Start --- Sure, if you can define what a "waiting command" is in your hardware design. --- Quote End --- I was thinking of a flag that would only make the sdram writing enable when it's '1'. --- Quote Start --- Have you created a simulation of your system? If not, you should. It will help you understand your design much better, since it gives you full visibility into what is going on. The simulation waveform view will also help you see why SignalTap II is useful. --- Quote End --- You're right, I haven't done so and I'm starting to think it's a big error. I'll do it first thing tomorrow (if my work let me enough time)...
