11 years agoData from FPGA to host
Hi, I have a DE0-nano board and I compute data (only 4 bits generated at about 10MHz) and I'd like to communicate it to the host cpu through the USB-blaster so programs could read it. I've read th...
11 years ago --- Quote Start --- For example it uses master_read_32 when reading the memory but I can't find what this command is doing. --- Quote End --- Often, you can use google to answer small questions like this (just plugin the function name to google). See page 10-44 (the 197th page of the PDF) of http://www.altera.com/literature/hb/qts/qts_qii5v3.pdf
