11 years agoData from FPGA to host
Hi, I have a DE0-nano board and I compute data (only 4 bits generated at about 10MHz) and I'd like to communicate it to the host cpu through the USB-blaster so programs could read it. I've read th...
11 years agoI was able to run the tutorial entirely and I read the tcl files (I don't know tcl but it is pretty simple to understand) and I don't find all the commands that are used. For example it uses master_read_32 when reading the memory but I can't find what this command is doing.
Someone told me using an sdram was tricky. Is all the complexity hidden somewhere? Where? How? I think I will use it to store my data and then read it by the host. Is there an easy way to do that?
