11 years agoData from FPGA to host
Hi, I have a DE0-nano board and I compute data (only 4 bits generated at about 10MHz) and I'd like to communicate it to the host cpu through the USB-blaster so programs could read it. I've read th...
11 years ago --- Quote Start --- When doing that, no other window/console opens. --- Quote End --- Hmm, that's weird. From the Start Menu, start a NIOS II Command Shell (under the NIOS II EDS folder), and then type system-console in that shell. I just did that on my install and system console started. If it fails on your setup, then I think you have an installation issue. Cheers, Dave
