11 years agoData from FPGA to host
Hi, I have a DE0-nano board and I compute data (only 4 bits generated at about 10MHz) and I'd like to communicate it to the host cpu through the USB-blaster so programs could read it. I've read th...
11 years ago --- Quote Start --- If you don't mind, I prefer to write on the forum so people can read. I often find solutions to my problems reading forums. --- Quote End --- Great! The fact that you can an error like "get_service_paths" means you have run the Tcl script in the wrong shell. That script needs to be run from within SystemConsole. After downloading the design to the DE0-nano, under Quartus II 13.1, you need to select Tools->System Console->System Console, and then once that starts up, you can source the Tcl script that contains the System Console commands, and then the sdram_test will work correctly. Yes, it would be nice if all Tcl consoles were the same :) Cheers, Dave
