11 years agoData from FPGA to host
Hi, I have a DE0-nano board and I compute data (only 4 bits generated at about 10MHz) and I'd like to communicate it to the host cpu through the USB-blaster so programs could read it. I've read th...
11 years agoHello,
I tried to post something but it doesn't appear, maybe because of an attached file. So I tried the sdram tutorial on http://www.alteraforum.com/forum/showthread.php?t=45927 but my console tells: Writing to 256 SDRAM locations Error:invalid command name "get_service_paths" Error: while executing Error:"unknown_original get_service_paths master" Error: ("eval" body line 1) Error: invoked from within Error:"eval unknown_original $cmd $args" Error: (procedure "::unknown" line 7) Error: invoked from within Error:"get_service_paths master" Error: (procedure "jtag_open" line 9) Error: invoked from within Error:"jtag_open" Error: (procedure "jtag_write" line 7) Error: invoked from within Error:"jtag_write $addr $data" Error: ("uplevel" body line 4) Error: invoked from within Error:"uplevel 1 $cmd" Error: invoked from within Error:"for {set i 0} {$i < $len} {incr i} { Error: set addr [expr {4*$i}] Error: set data [expr {0x12340000 + $i}] Error: jtag_write $addr $data Error: }" Error: (procedure "sdram_test" line 4) Error: invoked from within Error:"sdram_test" and I don't know what I should do. Do you understand the error?
