16 years agoDAC HSMC and EP3SL150F1152C2 stratix III
Hi im stuck with my stratix III EPSL150F1152C2 and the HSMC card that came with the board.. now my question is i cant get the output on the oscilloscope and when i try with signal tap i dont g...
16 years agoI did set up the pins as required (jumpper 15 and 17 pins 1 and 3 the ) but still cant get anything out..
1)is there suppose to be some input fruquency to which to run the DAC and if so what is the max or min? 2)what i have noticed is that i have to use the pin names as they appear in the datasheet is that correct(i mean the naming)? 3) i have chosen to use DAC_B and FPGA_CLK_B_P..my biggest worry is that even in the signal tap i cant get the analog waveforms and what i heard is that the signal tap should display what is suppose to be displyed on the oscilloscope,if i dont use the DAC will i still see the analog waveforms in the signal tap? sorry for so many questions but i really have to get this working..i have got a final demo on the 17 nov kind regards
