16 years agoDAC HSMC and EP3SL150F1152C2 stratix III
Hi im stuck with my stratix III EPSL150F1152C2 and the HSMC card that came with the board.. now my question is i cant get the output on the oscilloscope and when i try with signal tap i dont g...
16 years agoThree issues...
1. If you ran the installer that came with the Stratix III DSP development kit, it will have placed files at C:\altera\80\kits\stratixIII_3sl150_dsp. 2. You will need to set the DAC clock jumpers J15 and J17. Use the instructions in "data_conversion_hsmc_reference_manual.pdf" at C:\altera\80\kits\stratixIII_3sl150_dsp\documents. You can reference the board schematic at C:\altera\80\kits\stratixIII_3sl150_dsp\board_design_files\data_conversion_hsmc\schematic 3. Use the working example project located at C:\altera\80\kits\stratixIII_3sl150_dsp\examples\stratixIII_3sl150_dsp_example_ChA for FPGA pin assignments, analyzer configuration, etc. Hope this helps. Mike
