sm110
2 years agoCycloneXLP device
It is observed that all the outputs of cyclone X Lp device goes to high state till the configuration is completed. This will be a problem when the output is driving a device which require low on powe...
Ash_R_Altera
2 years agoHi,
Please refer to the following page 6.3.2. Configuration Sequence (intel.com). As per it, all the I/O pins are tied to an internal weak pull-up at power up, before configuration.
Solution to your requirement will be to connect on-board pull-down resistors for the output pins which are required to be low.
For the input pins, it does not matter, because the FPGA is not configured yet.
Hope that helps.
