sm110
2 years agoCycloneXLP device
It is observed that all the outputs of cyclone X Lp device goes to high state till the configuration is completed. This will be a problem when the output is driving a device which require low on powe...
sm110
2 years agoHello
You mean to say, whatever the output pins configured in the board, which require low level at power-on, should have a pull down resistor. Also the input pins which should be treated as low on power on should have a pull down resistor
