CAlex
Contributor
2 years agoCycloneVsoc GPIO multiple use question
Hi I have some questions about the pin multiplexing of this SOC. On the HPS component, I can choose to use set0, set1 or set2 of the UART pins (taking UART0 as an example), but according to the Cycl...
- 2 years ago
That's a schematic for a particular board design (I'm assuming a dev kit) so yes you'd have to use whatever those pins are connected to. Obviously, with your own board, you could choose whichever set of pins you wanted to use for the UART as long as you designed your board that way.
sstrell
2 years agoThat's a schematic for a particular board design (I'm assuming a dev kit) so yes you'd have to use whatever those pins are connected to. Obviously, with your own board, you could choose whichever set of pins you wanted to use for the UART as long as you designed your board that way.
