CAlex's avatar
CAlex
3 years ago
CycloneVsoc : How to use AMP mode
Hi
I want to have a fully baremetal system with AMP(which means I need two cores with baremetal system)
The questions are :
1. How to start the CPU1 in baremetal system ?
a) Do I need to change Uboot settings?
b) Do I need to change linker file?
c) If yes, then How.
2. How to communicate (signal / data) with each other?
3. How to debug the system?
Reguards
Alex
  • tehjingy_Altera's avatar
    tehjingy_Altera
    Hi Alex
    I am so sorry to inform you that running AMP is possible in running on the ARM processor in our SOC device, but we do not support software support in running in AMP mode.
    For real time operation Intel do provide solution with the Nios II and Nios V soft processor.
    Jingyang, Teh
    • CAlex's avatar
      CAlex
      do you know where can I get the help?
      Or do you know a way to start the CPU1 at CPU0 using baremetal system?
      Reguards
      Alex
    tehjingy_Altera
    Hi
    Since there are no feedback for this thread, I shall set this thread to close pending. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
    If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 10 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
    Jingyang, Teh
