16 years agoCycloneIII starter kit - basic question (clock)
Hi all, I am using the CycloneIII starter kit. I suppose that my question is general for any kind of dev kit. I am trying to run a simulation using the SignalTapII file. I think that I have a prob...
16 years agoYes, both pins are connected to the 50 MHz on-board oscillator, so either should work.
Unfortunately I can't guess, what you did wrong with your Signal Tap II instance without knowing the design (top level, pin assignments and Signal Tap). You may want to post a Quartus design archive.
