17 years agoCycloneIII Starter Board The CONF_DONE pin failed to go high in device 1
Hi,all I am a newer,if i have made some mistakes please don't laugh at me. I have an altera cycloneIII starter board,i used quartus II 7.2 to config it,it could finish and work before,but now at...
17 years agoHello. I had the same problem, but it was my mistake: you should check switch prog/run on your board. If use JTAG interface turn switch into run position, in the case using active serial programming you should choose prog position.
