18 years agoCYCLONEIII NIOS II Dev Kit Issue
Hi Guys, I am new, so please excuse my ignorance if any. I just got the CIII NII kit with the multimedia card from TerAsic. The standard sopc file has the SD/MMC card module for which we...
18 years agoThe "number of outputs" problem only arises for outputs in a Vref group with voltage referenced inputs, e. g. SSTL-2 used with DDR2 memory. You obviously revealed why not all LEDs had been connected. Actually there is a trick for outputs not toggling during normal operation. You make Quartus fitter ignore these pins in placement rules check by specifying a toggle rate 0 as discussed in AN 466, Cyclone III Design Guidelines on page 16.
