16 years agoCycloneIII FPGA Starter kit DDR clock pins and main oscillator voltage
Hi, I am designing a board with a CycloneIII device and some DDR memory. Having a look to the Cyclone III FPGA starter kit board, I can not quite understand a couple of points: - The m...
16 years agoDid this method work for you? Im seeing the same warning: The starter board was used as reference, and it worked fine (I dont even recall seeing the warning crop up...), but trying to use the PLL pins gives me warnings... and I'm worried they may turn into errors in a later version of Quartus...
Thanks!
