GordWait
4 months agoCyclone VGT Dev Kit boards - some new boards failing to boot from NOR Flash
We've been using these boards for years, having certified them for use in one of our products. In the last few months we have now received 5 of these boards and they fail to configure from NOR flash...
GordWait
3 months agoI can upload the timing report from my compilation of the factory Max5 build. Since it creates a pof file with the same checksum as the pof file found in the v22 CVGT release, I can only assume it has the same timing.
My understanding is that the Altera factory checksum values are:
Factory Binary Checksum 008D0C68 User Code 008D0C49
My build with the timing report below matches these checksums.
Here it is, attached.
Again, some of the boards we have received do not boot up with this factory build.
If you can get the actual compilation folder from the Altera engineering team who build the official v22 release, you can compare them.
I renamed it to .txt, it seemed like this forum would not let me upload the .rpt named original.
