JLee25
Contributor
6 years agoCyclone V Transceiver Design Missing
Hi, I follow the link to Cyclone V Transceiver PHY Design Example. And the link to "Cyclone V Native PHY with manual alignment, 8b10b enabled and byte ordering in single width mode design example...
CheepinC_altera
6 years agoHi,
Sorry for the delay. Frankly speaking, I am not sure why the Byte Order Pattern = 0x1BC in this example. My understanding is same as yours where we will need specific pattern ie 0xBC. Would you mind to try configuring the Native PHY to 0xBC to see if the byte ordering still working?
With the right pattern, if you sue BC60, the byte ordering should still work.
