JLee25
Contributor
6 years agoCyclone V Transceiver Design Missing
Hi, I follow the link to Cyclone V Transceiver PHY Design Example. And the link to "Cyclone V Native PHY with manual alignment, 8b10b enabled and byte ordering in single width mode design example...
JLee25
Contributor
6 years agoHi CheePin,
I ran the shared project and have questions need your help.
- Why the "Byte Order Pattern" is 0x1BC, and it can work properly when the input pattern is BCEE ?
- I change the TX signal from BCEE to BC60 and the Byte Order manual align still work?
My understanding about the Byte Ordering will arrange the output according to specified "Pattern".
But none of the above test pattern matched 1BC.
Do you think this result is correct?
BRs,
Johnson
