Cyclone V Jtag programming Failed
Hello there,
Interesting one ..quick thought ....Can you check with 6 MHz frequency? I believe by default it is 24 MHz.
Thank you,
Sree
- alberto_p7 years ago
thanks for the answer.
The frequency is 6 MHz... I searched around to change it but it seems to be the minimum frequency you can set.
In the meanwhile I tried again with the Jtag Chain Debugger and the IDCODE iteration test. It looks like, when I go up with iterations there is something wrong. I have a "Warning: Uncertain JTAG chain. Detected 1 device(s)". Not fully clear what it means but I am starting to think that, on a single iteration or with a few iterations, it works. As soon as I go high with iterations (which is also the case of a .sof file programming), there is something wrong with the bus. It is something that statistically happens: I cannot see it with a low number of iterations but when I go high it appears... Now, what exactly it is (TCLK, TDI, TDO...all of them..why it works with one bluster and not with the others....something else..)...no idea.
Regards.
