Qiyue_Wu's avatar
Qiyue_Wu
2 years ago
Cyclone V GT FPGA Development Kit jic download program
I am currently developing using the cyclone v gt fpga development kit, but I am having problems downloading the program to Flash. I followed intel's instructions and downloaded a MAX V program that allows the use of EPCQ256. However, when I downloaded the jic file to EPCQ256 using USB-Blaster, it failed with Error(209025). MSEL has been adjusted to fast AS mode. May I ask what is the cause of this problem?
  • We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum cases, along with others, did not get through as intended. As a result, we have a backlog of cases that we are currently working through one by one.
    Please be assured that we are doing everything we can to resolve this issue as quickly as possible. However, this process will take some time, and we kindly ask for your patience and understanding during this period. The cases will be attended by AE shortly.
    We appreciate your patience and understanding, and we are committed to providing you with the best support possible.
  • Hi,
    May I know if you still need help with this case? If yes, can you please try below:
    • Please check your MSEL setting is set correctly according to configuration scheme.\
    • Also, you may try to reduce the TCK frequency to 16MHz.
    Aiman
  • As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘ https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
