Cyclone V Frame Buffer II - problem with device Tree and with understanding the address map
Hi JakeJ,
You can refer to this document for more details. https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_vip.pdf
I cant see your qsys design from the blur pic. Anyway The address of your frame buffer II IP will be based on it's base address in your qsys desgin, it can be manual or auto assigned in platform designer as long as it does not overlapped with the address range used by other IP in the design. The register control address of a particular IP is the offset from it's base address, example base address + offset address.
Aik Eu
Hi @aikeu , thank you for response. I don't know what's the cause of blurring - the problem doesn't occur on my side and the picture is sharp. Anyway, I made some changes since last time. I connected control registers to lightweight HPS-to-FPGA bridge at offset 0 - so the base address is ff200000 - and I configured framebuffer IP as Frame Reader only.
This is the current qsys project:
the address map:
and the device tree:
The problem is presented below:
[ 5.541922] Unable to handle kernel NULL pointer dereference at virtual address 00000160
[ 5.550015] pgd = (ptrval)
[ 5.552717] [00000160] *pgd=00000000
[ 5.556348] Internal error: Oops: 5 [#1] SMP ARM
[ 5.560963] Modules linked in: altvipfb2_drv(+) cfbfillrect cfbimgblt cfbcopyarea
[ 5.568447] CPU: 0 PID: 87 Comm: udevd Not tainted 5.12.0-altera #1
[ 5.574695] Hardware name: Altera SOCFPGA
[ 5.578691] PC is at dma_alloc_attrs+0x38/0x128
[ 5.583223] LR is at altvipfb2_probe+0x74/0xccc [altvipfb2_drv]
[ 5.589145] pc : [<c019a690>] lr : [<bf0133a8>] psr: 600d0013
[ 5.595387] sp : c1dcbb98 ip : c1dcbbd0 fp : c1dcbbcc
[ 5.600592] r10: c1a042ac r9 : bf015014 r8 : c1a04128
[ 5.605795] r7 : c1245c10 r6 : c1245c10 r5 : 00000cc0 r4 : 00000000
[ 5.612295] r3 : 00000000 r2 : c1a04128 r1 : 0012c000 r0 : 00000000
[ 5.618797] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none
[ 5.625917] Control: 10c5387d Table: 01f4804a DAC: 00000051
[ 5.631663] Process udevd (pid: 87, stack limit = 0x(ptrval))
[ 5.935027] Backtrace:
[ 5.937469] [<c019a658>] (dma_alloc_attrs) from [<bf0133a8>] (altvipfb2_probe+0x74/0xccc [altvipfb2_drv])
[ 5.947030] r8:f0821000 r7:c1245c10 r6:c1245c10 r5:00000000 r4:c1a04040
[ 5.953702] [<bf013334>] (altvipfb2_probe [altvipfb2_drv]) from [<bf013198>] (altvipfb2_plat_probe+0x178/0x23c [altvipfb2_drv])
[ 5.965159] r10:00000004 r9:bf015014 r8:ef7f6d5c r7:00000000 r6:c1245c10 r5:c1245c00
[ 5.972954] r4:c1a04040
[ 5.975476] [<bf013020>] (altvipfb2_plat_probe [altvipfb2_drv]) from [<c061b024>] (platform_probe+0x6c/0xc8)
[ 5.985290] r8:00000000 r7:c0dda024 r6:bf015014 r5:c1245c10 r4:00000000
[ 5.991962] [<c061afb8>] (platform_probe) from [<c0618520>] (really_probe+0xf4/0x4b8)
[ 5.999773] r7:c0dda024 r6:00000000 r5:c0dda01c r4:c1245c10
[ 6.005407] [<c061842c>] (really_probe) from [<c0618950>] (driver_probe_device+0x6c/0xc4)
[ 6.013565] r10:00000024 r9:c1dcbf30 r8:c1e88e48 r7:bf015014 r6:c1245c54 r5:bf015014
[ 6.021360] r4:c1245c10
[ 6.023882] [<c06188e4>] (driver_probe_device) from [<c0618fc4>] (device_driver_attach+0xb8/0xc0)
[ 6.032727] r5:00000000 r4:c1245c10
[ 6.036286] [<c0618f0c>] (device_driver_attach) from [<c061905c>] (__driver_attach+0x90/0x120)
[ 6.044874] r7:c0d800f0 r6:c1245c10 r5:bf015014 r4:00000000
[ 6.050509] [<c0618fcc>] (__driver_attach) from [<c06161a0>] (bus_for_each_dev+0x88/0xd0)
[ 6.058663] r7:c0d800f0 r6:c0618fcc r5:bf015014 r4:00000000
[ 6.064298] [<c0616118>] (bus_for_each_dev) from [<c0617dbc>] (driver_attach+0x2c/0x30)
[ 6.072278] r6:00000000 r5:c1e88480 r4:bf015014
[ 6.076875] [<c0617d90>] (driver_attach) from [<c061774c>] (bus_add_driver+0x108/0x1f0)
[ 6.084854] [<c0617644>] (bus_add_driver) from [<c0619ba4>] (driver_register+0x98/0x128)
[ 6.092922] r7:00000000 r6:ffffe000 r5:00000000 r4:bf015014
[ 6.098556] [<c0619b0c>] (driver_register) from [<c061ad28>] (__platform_driver_register+0x2c/0x34)
[ 6.107576] r5:bf018000 r4:c0daed60
[ 6.111135] [<c061acfc>] (__platform_driver_register) from [<bf018028>] (altvipfb2_driver_init+0x28/0x1000 [altvipfb2_drv])
[ 6.122236] [<bf018000>] (altvipfb2_driver_init [altvipfb2_drv]) from [<c01021bc>] (do_one_initcall+0x68/0x260)
[ 6.132301] [<c0102154>] (do_one_initcall) from [<c01c0b80>] (do_init_module+0x70/0x2a4)
[ 6.140372] r7:00000000 r6:00000002 r5:c11dab80 r4:bf015100
[ 6.146006] [<c01c0b10>] (do_init_module) from [<c01c3368>] (load_module+0x2498/0x29a4)
[ 6.153988] r6:00000002 r5:c1e88e00 r4:00000002
[ 6.158585] [<c01c0ed0>] (load_module) from [<c01c3acc>] (sys_finit_module+0xc8/0x104)
[ 6.166483] r10:0000017b r9:c1dca000 r8:c0100264 r7:0000017b r6:0000000c r5:b6e757ac
[ 6.174278] r4:00000000
[ 6.176800] [<c01c3a04>] (sys_finit_module) from [<c0100060>] (ret_fast_syscall+0x0/0x58)
[ 6.184951] Exception stack(0xc1dcbfa8 to 0xc1dcbff0)
[ 6.189985] bfa0: 004ce1a0 00000000 0000000c b6e757ac 00000000 004d6e38
[ 6.198131] bfc0: 004ce1a0 00000000 00000000 0000017b 00020000 004d6e38 00000000 00000000
[ 6.206273] bfe0: becb4d40 becb4d30 b6e6d254 b6df0220
[ 6.211305] r6:00000000 r5:00000000 r4:004ce1a0
[ 6.215906] Code: e1a08002 e5933000 e50b3028 e3a03000 (e5946160)
[ 6.222018] ---[ end trace 1b5948a3b2f7d597 ]---
[ 6.233084] udevd[82]: worker [87] terminated by signal 11 (Segmentation fault)
[ 6.244373] udevd[82]: worker [87] failed while handling '/devices/platform/soc/ff200000.vip'
I have some doubts about Frame buffer memory base address property in IP configuration. I don't know what I should be guided by when adjusting its value.
Jake
