TaeHoLee
2 years agoCyclone V device difference between 5CEBA7F23C7 and 5CEFA7F23I7
I programmed using the Cyclone V device, 5CEBA7F23C7, and it operated normally. I changed the device to 5CEFA7F23I7, confirmed pin-to-pin compatibility, and didn't use HMC. Instead, I implemented the ...
NurAiman_M_Intel
2 years agoHi,
To make my understanding clear, there is no solder or resolder occur on the same board? Meaning you did not resolder device 5CEBA7F23C7 then solder 5CEFA7F23I7 to replace the 1st device? You just created multiple boards by maintaining the same circuit and layout and directly replace with 5CEFA7F23I7?
I saw my colleague are also supporting you with the same issue in https://community.intel.com/t5/Programmable-Devices/Cyclone-V-Pulling-excessive-current-at-3-3V/m-p/1561447 ? Is it Ok if i close this thread and you can continue to get support from my colleague in the other thread?
Aiman
