TaeHoLee
2 years agoCyclone V device difference between 5CEBA7F23C7 and 5CEFA7F23I7
I programmed using the Cyclone V device, 5CEBA7F23C7, and it operated normally. I changed the device to 5CEFA7F23I7, confirmed pin-to-pin compatibility, and didn't use HMC. Instead, I implemented the ...
NurAiman_M_Intel
2 years agoHi,
- What pin that you are measuring?
- You said that you changed the device from 5CEBA7F23C7 to 5CEFA7F23I7, did you also change the board?
- If you are using the same board, did you re-solder or solder the board/device when changing the device? It could be the board issue.
AIman
- TaeHoLee2 years ago
The board used was originally designed for the 5CEBA7F23C7 chip, and then multiple boards were created by maintaining the same circuit and layout while replacing the chip with 5CEFA7F23I7.
Is it correct to understand that, generally, when you change only the device on the same board, there are no issues with heat or current?
Thank you.
