cyclone v ddr3
- 3 years ago
hello again,
ok i think i understands the addressing now.
the address[29:0] uses only [29:4].(26 bits out of 30). and the 4 bits left are just padding.
correct me if im wrong.
thanks,
Ram.
Hi Ram,
Thank you for submitting your question in Intel Community.
I'm Adzim will assist you in this thread.
The avalon local address is a parameter that store the location of the bank that to be accessed during the read and write memory transaction.
It's combination of chip select bits + row bits + bank bits + column - N where N is 1 for full-rate controller and 2 for half-rate controller.
The order of address mapping is based on the "Local-to-Memory Address Mapping" setting in the IP.
The memory address is determined the operation of the memory. This can be referred to memory datasheet in the truth table.
For read and write operation, there is timing diagram that illustrated the read and write operation in the EMIF handbook volume 3 starting on page 440.
Link: https://www.intel.com/programmable/technical-pdfs/683841.pdf#page=440
Adzim
