TerraX
4 years agoCyclone V - Differential Pair Pin Assignment 1.5V PCML fitter error
When creating a new Quartus project similar to a demo example, I am trying to place XCVR pins in a blank project and getting an error from the 1.5V PMCL differential pins (HSMC_GXB_RX_p0 and HSMC_GXB...
- 4 years ago
Hi Terra,
I have told you earlier, you cannot directly connect, Please design custom logic to reconstruct the word. First correct your design then try to compile.
Thank you
Kshitij Goel
TerraX
4 years agoOne idea I have about this error message is that the Clock pin I'm using for the PLL (CLOCK_50_B7A on Bank 7) is on a separate bank from the Tx & Rx pins (which are on bank GXB_L0). If that is the case, then I only have REFCLK_p0 to work with as the input to the PLL since it is on the same bank as the Rx & Tx pins I am trying to connect together. Does that sound about right?
