TerraX
4 years agoCyclone V - Differential Pair Pin Assignment 1.5V PCML fitter error
When creating a new Quartus project similar to a demo example, I am trying to place XCVR pins in a blank project and getting an error from the 1.5V PMCL differential pins (HSMC_GXB_RX_p0 and HSMC_GXB...
- 4 years ago
Hi Terra,
I have told you earlier, you cannot directly connect, Please design custom logic to reconstruct the word. First correct your design then try to compile.
Thank you
Kshitij Goel
TerraX
4 years agoI've switched to Quartus Prime 21.1 and added the IP Core for "SDI II Intel FPGA IP"
I selected the options for Transceiver Only, Bidirectional, HD-SDI, and 74.25MHz
Then I added a PLL to provide the clock, but it doesn't seem to compile with the PLL.
Thank you for your help. I created the Archive .qar file and attached it.
