Cyclone V - CLK[0:11][P:N] Connection
- 2 years ago
"Please your support understanding what is the impact of connecting the CLK[0:11]N pins with 5K pull-down resistor to GND instead of tied to GND?"
I don't see 5k pull-down for unused clock input suggested in an Intel document, and I don't see a specific advantage or "impact".
Cyclone V is providing weak pull-up and other options to bias unconnected input pins, different from other FPGA families, the option is also available for clock pins. We see grounded unused clock pins with other FPGA families that don't have this bias option for clock pins.
Pull-down resistors are partly suggested for unused refclock inputs of gigabit transceivers. These pins use different I/O standards and have therefore different requirements. It makes no sense to copy the suggestion for standard clock inputs.
Hi FvM,
Thank you for your reply.
Just to clarify:
In case of connecting a single-ended input clock, negative pin considered as unused input pin? isnt it the return path of this specific logic?
Roy Roif
