11 years agoCyclone IV Transciever Starter Kit Automation Issue MAX_error LED stuck on.
We have an automated test system running with Cyclone IV Transciever Cards acting as PCIe EP's. Our automation system load the .elf to the card memory via a NIOS console running on a host PC. ...
11 years ago --- Quote Start --- Solved ..... --- Quote End --- Not so fast ... :) --- Quote Start --- I took a Cyclone card to my office, connected it to USB on my Laptop and ran nios2-terminal from the NIOS Command Shell and got a connection. Next, I powered down the Cyclone card and then powered back on using the brick power and the card power slide switch. The resulting behavior is a red MAX_ERROR LED. I will tell the automation team not to do it or to somehow release the connection before cycling the Cyclone PCIe slot power. . --- Quote End --- Just to avoid confusion on my part, can you run through this sequence without using nios2-terminal? I just plugged in my card, and no combination of power cycling, unplugging the USB connector, or power cable with or without toggling the power switch off causes a red LED to come on. If you can establish that its the nios2-terminal connection that causes the issue, then you can probably disconnect, power-cycle, and then reconnect. Cheers, Dave
