15 years agoCyclone IV transceiver Dev Kit Example compiles with errors.
My Cyclone IV transceiver Dev Kit Example compiles with errors. It appears to be looking for "bts_general_sopc_inst" but cannot find it. The fatal compile error listed is: Error: Node insta...
15 years agoThank you for the tip. I will check the schematic of the board to see if there are any termination resistors at this node. If not then I will change the
parameter after checking to see what impedance my device supports. Thanks again, Bob
