11 years agoCyclone IV Hard IP and MSI generation
I want to generate MSI's from the Cyclone IV Transciever Development Kit board ... searches indicate the PCIe Compiler can help but I have never had success in generation or modifying the existing P...
11 years agoI may try to answer this myself, since a MSI is a write to a given address with some payload, I can't se anything special required to generate the MSI except to create a CRA translation entry to translate the NIOS II write to the RC interrupt controller instead of to the RC DDR address.
The component mentioned may be a dedicated Master with the req / ack hooks required for some other hardware block to launch the interrupt.
