13 years agoCyclone IV GX starter kit SSRAM access
Hi, if anyone made the link work, could you share a link or some tips? I checked the schematic. It seems the control signals to the ISSI SSRAM need to go through the MAX II chip(EPM2210) since the Cy...
13 years agoIt looks like the JTAG to Avalon Master Bridge used in bts_general sample code doesn't support burst transfers. Since the bridge has a 32bits bus and the SRAM has 16bits so there is a burst of 2 transfers seen on the SRAM data bus. I would expect the 2 data transfers on the SRAM bus take 2 clocks but it takes a lot more as seen on SignalTap(of course, if you consider the command on the SRAM bus it would take more than 2 clocks but 2 clocks are enough for the data only). Maybe there is a way to optimize the timing of the transfer by choosing the parameters.
